Date/Time: Wed, 22 Jan 2025 15:48:35 +0000
Unable to connect
View Count: 656
[2018-10-12 14:56:57]
gmorgan111 - Posts: 121
I just lost connection to the trading server. My internet is fine. I am able to access all websites with the same speed.
I am sending the log to you.
Is there a problem on your end? I use Rithmic
[2018-10-12 14:57:37]
User296719 - Posts: 21
If you're using Rithmic as your datafeed, it appears to be down right now with SC.
[2018-10-12 16:52:35]
There is an issue on the Rithmic side related to this. For a technical explanation of why we cannot solve this, refer to:
Rithmic Data Connection Failure | Post: 149895
We will be contacting Rithmic about this today.
