Date/Time: Thu, 23 Jan 2025 05:17:10 +0000
Exchange traded spread chart/dom
View Count: 1428
[2018-10-12 11:05:43] |
User579247 - Posts: 1 |
Hi I have a problem with charts and the DOM on exchange traded spreads, maybe it's just a setting i do not know about though. I have posted link with images of the problem that i have. On HOF9-HOG9-NYMEX i can't see correct prices on chart (it's 0.003 even if price moved up/down a few ticks). And in the DOM the order depth is clunked together. On ZWZ8-ZWH9-CBOT the chart prices have extra prices between ticks but otherwise it looks correct. In the DOM there are extra prices also so the order depth is spaced out. http://www.sierrachart.com/image.php?Image=1539341634794.png http://www.sierrachart.com/image.php?Image=1539341976786.png Best regards, Js |
[2018-11-15 18:59:31] |
Check the Tick Size and Price Display Format in Chart Settings to make sure they are correct for the symbol: http://www.sierrachart.com/index.php?page=doc/ChartSettings.html#TickSize And follow the instructions here to auto scale the Chart DOM once the tick size is set correctly: http://www.sierrachart.com/index.php?page=doc/ScalingTheChartDOM.html#AutoScale Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-11-15 19:00:51
