Date/Time: Wed, 22 Jan 2025 16:58:41 +0000
[Programming Help] - Paint an Indicator (Study)
View Count: 759
[2018-10-11 18:41:36] |
User750920 - Posts: 280 |
Is it possible to paint an indicator (study). Specifically, the ADX. I want to pain the line a different color based on the value of the study as it rises and falls the color will change when it is below or above 3 different values. Thank you. |
[2018-10-11 19:28:16] |
Yes. Refer to: Color Bar Based on Alert Condition: Coloring Subgraphs of Other Studies Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-10-11 20:28:19] |
I works and shows up, however the alert colored line is right above the original ADX line (a different color) Is there a way to set it so that it replaces (colors over the original color of the line) so it looks cleaner and seamless.
