Date/Time: Wed, 22 Jan 2025 17:09:02 +0000
Spreadsheet System for Trading - "Maximum Position Allowed in Same Direction"
View Count: 603
[2018-10-11 18:37:52] |
User944883 - Posts: 1 |
I cannot locate above field (referred to in Step 11 under 'Creating a Trading System for Automated Trading' in 'Spreadsheet Systems, Alerts, and Automated Trading') in the Input Name Box on the Settings and Inputs tab of the Study Settings for the 'Spreadsheet System for Trading' study. The closest field I see is 'Maximum Position Allowed' but this does not appear to the same thing. I am using version 1815. Please clarify. Thanks.
[2018-10-11 19:13:47] |
ForgivingComputers.com - Posts: 989 |
I think the answer is that you cannot have a position in each direction at the same time, so "in same direction" is irrelevant.
[2018-10-11 19:35:28] |
The documentation has been updated and clarified in regards to this.
