Date/Time: Wed, 22 Jan 2025 17:07:10 +0000
brackets
View Count: 604
[2018-10-11 18:36:12]
User672082 - Posts: 62
I have never did this through the DOM before, always manually. I am sure it is the SC material but I could not find it. What I want to set up the SC DOM is the following. I want to set this up so it automatic as possible, even though I am discretionary in my trading. I know my strengths and weaknesses. : The following numbers are for CL futures.
My first entry, say 2 contracts, if/when it goes AGAINST me 30 cents, it will add my other 2 contracts, for my full boat of 4.
At 75 cents full stop out on ALL contracts.
When/if the position moves in my favor, at thirty cents, I take half of the position off and move to break even on the remaining half.
At fifty cents in profit, the BE stops moves to a trailing stop, trailing the remainder by 20 cents. I have no targets, except the first one and let the market take out the rest.
The only issue I haven't figured out yet is how to add a full boat if the position goes into profit right upon entry and does not give me my chance to add when it goes against me a bit. Perhaps on some type of pullback? But, then I have to manually change the stop loss amount, which I guess I have to do in either situation. Because if the initial stop is based on the initial entry, regardless if I add to my position in profit or add if it goes against me, I will have to change it manually, I think. Rarely am I exactly right on initial entry and need to give the entry a bit of "wiggle" room.
[2018-10-11 19:39:34]
Here is the documentation for Attached Orders:
Attached Orders
It sounds like you also want to use a Triggered Trailing Stop for one of the Attached Orders:
Order Types: Triggered Trailing Stop
Not everything you want to do is supported like this:
Date Time Of Last Edit: 2018-10-11 19:40:09
