Date/Time: Wed, 22 Jan 2025 15:57:01 +0000
point ABCD Tool
View Count: 1098
[2018-10-11 17:02:28]
markuz - Posts: 90
Is there a tool or study that you can draw between points and then have it label the points automatically? (example attached)
imagePoint tool.jpg / V - Attached On 2018-10-11 17:02:13 UTC - Size: 59.63 KB - 432 views
[2018-10-12 14:08:40]
John - SC Support - Posts: 37369
The Zig Zag tool is the closest that Sierra Chart has available, in that it allows you to draw the lines as you want, but it does not automatically label the end points.
[2018-10-12 19:16:04]
Here is the documentation for the zig zag tool:
Chart Drawing Tools: Zig-Zag
And you may also find the custom text drawings useful as well:
Chart Drawing Tools: Custom Text Drawing Control Bar Buttons
Date Time Of Last Edit: 2018-10-12 19:16:17
[2018-10-12 19:32:52]
markuz - Posts: 90
Thank you very much!
