Date/Time: Wed, 22 Jan 2025 16:54:00 +0000
how to open new Symbol with same chart format setup
View Count: 671
[2018-10-11 07:23:09] |
User318681 - Posts: 1 |
[2018-10-11 09:21:57] |
Xfanman1 - Posts: 320 |
Simply right click the chart tab that you wish to duplicate. Select Duplicate Chart on the tab (or on the active chart in the Chart menu settings). On your new chart just change the symbol to what you wish the new chart to be. Make sure the new chart is unlinked from the original though before you change the symbol or you’ll change both charts symbols if you had linking set up originally. See the details here—> Using Chart Templates Scott Date Time Of Last Edit: 2018-10-11 09:24:04
[2018-10-11 17:58:49] |
Here is the relevant documentation for this: Using Chart Templates Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
