Date/Time: Wed, 22 Jan 2025 16:54:52 +0000
latest version
View Count: 669
[2018-10-10 16:26:09] |
Crtfyd - Posts: 281 |
Downloaded latest version I use TransAct to trade. I noticed under TRADE>...two lines are checked. "Disable Auto Trading on Startup", and "Auto Trading Enabled-Chart": This is confusing. I dont trade from the charts, so it seems "Disable at Start-up" should be checked. I didnt check this one, and it seems it shouldnt be checked (the"Auto Trading Enable"). It would seem that both couldnt be enabled together as they are opposite. I would want to SIM trade. Its not clear to me which is your new trading, and which are your SIM trading lines. Should I UNcheck the "Auto Trading Enabled-Chart"? Seeing as I don't LIVE trade from the Chart? Thx |
[2018-10-10 18:03:45] |
Those are all documented here: Trade Menu And they are not new. They are not relevant for manual trading. You can disregard them. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
