Date/Time: Fri, 31 Jan 2025 19:56:41 +0000
Exporting Inputs and variables
View Count: 911
[2018-10-10 11:45:43]
User470516 - Posts: 78
Dear Sierra Chart Team,
1- Is it possible to export inputs and variables defined in studies (and visible in "settings and inputs" of the study window) to excel or access so that the export of subgraph data can be related to their associated inputs?
2- Is it possible from a study to access to those inputs in other charts in a similar way we access study arrays from a different chart?
Thank you for the support!
Regards,
Laurent
[2018-10-10 21:54:55]
1. No.
2. Refer to:
sc.GetChartStudyInputFloat()
[2019-05-30 02:01:02]
uM8137 - Posts: 183
Corresponding to sc.GetChartStudyInput{Int,Float,String}(), it would be very nice to be able to get the Name of the field from the study. For example, by calling the hypothetical additional API function
sc.GetChartStudyInputName()
This would be very helpful for confirming that the expected Int,Float,String field has not been moved by a recent field addition or reordering. Also it would let us discover the number of fields, as this is not otherwise available, since only named fields are shown.
sc.GetChartStudyInputType() returning an enum of INT_FIELD, DOUBLE_FIELD, INDEX_FIELD, STRING_FIELD would also be very helpful in properly introspecting.
Thank you for considering these additions.
Date Time Of Last Edit: 2019-05-30 02:15:05
