Date/Time: Sun, 24 Nov 2024 11:13:31 +0000
Tick data with IB for Canada
View Count: 1400
[2013-10-28 20:29:47] |
superdoug3 - Posts: 40 |
I want to trade Futures and need good tick data and I live in B.C. Canada. My options are limited. I read this thread from 2010 regarding IQFeed with IB - https://www.sierrachart.com/supportboard/showthread.php?t=25018&highlight=ib+iqfeed+futures is this still the most current approach to having IQfeed build my charts and sending trades to IB. i.e. 2 instances of SC |
[2013-10-29 00:34:26] |
Yes, that does make sense. You may also want to look at the Barchart data feed: http://www.sierrachart.com/index.php?l=doc/Barchart.com.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
