Date/Time: Wed, 22 Jan 2025 16:51:13 +0000
Need Study Subtract from Constant
View Count: 619
[2018-10-10 05:34:45] |
User360283 - Posts: 506 |
How to have a sturd subtract from a constant? Example: Subtract Study ID n SG n from 100 Thanks |
[2018-10-10 22:59:43] |
You would need to use a combination of the Arithmetic Studies (Using the Basic Arithmetic Studies). In particular, you would need to use Study Subgraph Subtract to subtract 100 from the original study, then use Study Subgraph Absolute Value on the Subgraph from Study Subgraph Subtract. Another option would be to use the Spreadsheet Formula and just enter the formula: = 100 - IDn.SGm Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
