Date/Time: Wed, 22 Jan 2025 14:50:28 +0000
Data
View Count: 567
[2018-10-10 03:47:31] |
User579342 - Posts: 16 |
What are costs if i have 2 logins to same account from my broker that are both enabled for Sierra? Can i do this ? is it allowed? meaning I want to run sierra on 2 seperate computers simultaneously same acount. I have your Sierra data feed as well. costs for running second version of Sierra and any additional costs for data/exchange fees? thx |
[2018-10-10 04:01:41] |
There is no additional cost for Sierra Chart for this but using the Sierra Chart Exchange Data Feed on two instances of Sierra Chart at the same time requires you pay for a second connection. Refer to: https://www.sierrachart.com/UserControlPanel.php?page=ExchangeDataFeedFeatures#DataConnections There is no additional cost for the exchange fees. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
