Date/Time: Wed, 22 Jan 2025 14:53:37 +0000
No charts loaded....what is wrong
View Count: 797
[2018-10-10 02:44:13]
User919070 - Posts: 3
My charts will not load. I get a blank page. There are errors in the log during start up
Please help
[2018-10-10 03:42:42]
Restart Sierra Chart and then open one of your Chartbooks through File >> Open Chartbook.
After that provide a copy of the Message Log, following these instructions:
https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog
[2018-10-10 04:11:54]
Reading Internal Order ID file. | 2018-10-10 04:08:54
Reading Trade Orders file. | 2018-10-10 04:08:54
Reading Trade Positions and Account Balance file. | 2018-10-10 04:08:54
Listening on UDP port 22904. | 2018-10-10 04:08:54
Software version: 1815 64-bit | 2018-10-10 04:08:54
Usage end date: 2018-11-03 | 2018-10-10 04:08:54
Enabled for: Advanced Features. | 2018-10-10 04:08:54
Enabled for: Advanced Features 2. | 2018-10-10 04:08:54
Enabled for: Sierra Chart Historical Data Service. | 2018-10-10 04:08:54
Allow Support for Sierra Chart Data Feeds is enabled. | 2018-10-10 04:08:54
Current selected Data/Trading service: SC Data - All Services | 2018-10-10 04:08:54
Chart Update Interval: 500 | 2018-10-10 04:08:54
Time Zone: +00:00:00 (UTC+00) | 2018-10-10 04:08:54
2018-10-10 00:08:53 Local computer time | 2018-10-10 04:08:54
2018-10-10 04:08:53 Local computer time in UTC | 2018-10-10 04:08:54
2018-10-10 04:08:53 Local computer time in SC Time Zone | 2018-10-10 04:08:54
2018-10-10 04:08:51 Server time in UTC | 2018-10-10 04:08:54
Local computer UTC time and Server UTC time difference: 2 seconds. | 2018-10-10 04:08:54
Program path: C:\SierraChart\ | 2018-10-10 04:08:54
Data Files path: C:\SierraChart\Data\ | 2018-10-10 04:08:54
OS Version Number: 6.1 | 2018-10-10 04:08:54
Locale Setting: C | 2018-10-10 04:08:54
Checking for new symbol settings for service code scdataallservices | 2018-10-10 04:08:54
HTTPS www.sierrachart.com:443 (4) | Creating socket. Using TLS 1.2. | 2018-10-10 04:08:54
HTTPS www.sierrachart.com:443 (4) | Connecting to IP: 204.15.192.108. | 2018-10-10 04:08:54
Received 5 login tokens. | 2018-10-10 04:08:54
HTTPS www.sierrachart.com:443 (5) | Creating socket. Using TLS 1.2. | 2018-10-10 04:08:56
HTTPS www.sierrachart.com:443 (5) | Connecting to IP: 204.15.192.108. | 2018-10-10 04:08:56
Symbol settings are up-to-date for scdataallservices | 2018-10-10 04:08:57
HTTPS login.sierrachart.com:443 (1) | Socket gracefully closed by remote side. | 2018-10-10 04:08:58
HTTPS login.sierrachart.com:443 (1) | Received socket Close event. | 2018-10-10 04:08:58
HTTPS login.sierrachart.com:443 (1) | Signaling to core to close socket | 2018-10-10 04:08:58
HTTPS login.sierrachart.com:443 (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-10-10 04:08:58
HTTPS login.sierrachart.com:443 (1) | Closed. | 2018-10-10 04:08:58
SC Data - All Services | Connected to data server. | 2018-10-10 04:08:59
HTTPS www.sierrachart.com:443 (2) | Socket gracefully closed by remote side. | 2018-10-10 04:08:59
HTTPS www.sierrachart.com:443 (2) | Received socket Close event. | 2018-10-10 04:08:59
HTTPS www.sierrachart.com:443 (2) | Signaling to core to close socket | 2018-10-10 04:08:59
HTTPS www.sierrachart.com:443 (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-10-10 04:08:59
HTTPS www.sierrachart.com:443 (2) | Closed. | 2018-10-10 04:08:59
HTTPS www.sierrachart.com:443 (5) | Socket gracefully closed by remote side. | 2018-10-10 04:09:01
HTTPS www.sierrachart.com:443 (5) | Received socket Close event. | 2018-10-10 04:09:01
HTTPS www.sierrachart.com:443 (5) | Signaling to core to close socket | 2018-10-10 04:09:01
HTTPS www.sierrachart.com:443 (5) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-10-10 04:09:01
HTTPS www.sierrachart.com:443 (5) | Closed. | 2018-10-10 04:09:01
HTTPS www.sierrachart.com:443 (4) | Socket gracefully closed by remote side. | 2018-10-10 04:09:02
HTTPS www.sierrachart.com:443 (4) | Received socket Close event. | 2018-10-10 04:09:02
HTTPS www.sierrachart.com:443 (4) | Signaling to core to close socket | 2018-10-10 04:09:02
HTTPS www.sierrachart.com:443 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-10-10 04:09:02
HTTPS www.sierrachart.com:443 (4) | Closed. | 2018-10-10 04:09:02
Chart (EMDZ8-CME) | Error loading Custom Studies DLL: C:\SierraChart\Data\PPTTATSTIII_64.dll. Windows error code 126: The specified module could not be found. | 2018-10-10 04:09:21 *
Chart (EMDZ8-CME) | Error loading Custom Studies DLL: C:\SierraChart\Data\PPATDelta33_64.dll. Windows error code 126: The specified module could not be found. | 2018-10-10 04:09:21 *
Custom studies file does not exist: C:\SierraChart\Data\PPTTATArrowStarII_64.dll | 2018-10-10 04:09:21
Custom studies file does not exist: C:\SierraChart\Data\SikatnaShilo_64.dll | 2018-10-10 04:09:21
EMDZ8-CME 10 Min #2 | Reloading chart. | 2018-10-10 04:09:21
Chart (ESZ8-CME) | Error loading Custom Studies DLL: C:\SierraChart\Data\PPTTATSTIII_64.dll. Windows error code 126: The specified module could not be found. | 2018-10-10 04:09:21 *
Chart (ESZ8-CME) | Error loading Custom Studies DLL: C:\SierraChart\Data\PPATDelta33_64.dll. Windows error code 126: The specified module could not be found. | 2018-10-10 04:09:21 *
ESZ8-CME 10 Min #1 | Reloading chart. | 2018-10-10 04:09:21
Chart (NQZ8-CME) | Error loading Custom Studies DLL: C:\SierraChart\Data\PPTTATSTIII_64.dll. Windows error code 126: The specified module could not be found. | 2018-10-10 04:09:21 *
Chart (NQZ8-CME) | Error loading Custom Studies DLL: C:\SierraChart\Data\PPATDelta33_64.dll. Windows error code 126: The specified module could not be found. | 2018-10-10 04:09:21 *
NQZ8-CME 10 Min #3 | Reloading chart. | 2018-10-10 04:09:21
Chart (YMZ8-CBOT) | Error loading Custom Studies DLL: C:\SierraChart\Data\PPTTATSTIII_64.dll. Windows error code 126: The specified module could not be found. | 2018-10-10 04:09:21 *
Chart (YMZ8-CBOT) | Error loading Custom Studies DLL: C:\SierraChart\Data\PPATDelta33_64.dll. Windows error code 126: The specified module could not be found. | 2018-10-10 04:09:21 *
YMZ8-CBOT 10 Min #4 | Reloading chart. | 2018-10-10 04:09:21
EMDZ8-CME 10 Min #2 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\EMDZ8-CME.scid | 2018-10-10 04:09:21
ESZ8-CME 10 Min #1 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\ESZ8-CME.scid | 2018-10-10 04:09:21
NQZ8-CME 10 Min #3 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\NQZ8-CME.scid | 2018-10-10 04:09:21
YMZ8-CBOT 10 Min #4 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\YMZ8-CBOT.scid | 2018-10-10 04:09:21
SC Data - All Services | Starting real-time market data updates for: EMDZ8-CME. ID: 1 | 2018-10-10 04:09:21
SC Data - All Services | Subscribing to streaming market data in the service client is not supported. Symbol: EMDZ8-CME | 2018-10-10 04:09:21
SC Data - All Services | Requesting security definition data for: EMDZ8-CME. ID: 1 | 2018-10-10 04:09:21
Intraday data recording state for symbol EMDZ8-CME is set to download 'Pending'. | 2018-10-10 04:09:21
Delaying start of download for EMDZ8-CME | 2018-10-10 04:09:21
SC Data - All Services | Starting real-time market data updates for: ESZ8-CME. ID: 2 | 2018-10-10 04:09:21
SC Data - All Services | Subscribing to streaming market data in the service client is not supported. Symbol: ESZ8-CME | 2018-10-10 04:09:21
SC Data - All Services | Requesting security definition data for: ESZ8-CME. ID: 2 | 2018-10-10 04:09:21
Intraday data recording state for symbol ESZ8-CME is set to download 'Pending'. | 2018-10-10 04:09:21
SC Data - All Services | Starting real-time market data updates for: NQZ8-CME. ID: 3 | 2018-10-10 04:09:21
SC Data - All Services | Subscribing to streaming market data in the service client is not supported. Symbol: NQZ8-CME | 2018-10-10 04:09:21
SC Data - All Services | Requesting security definition data for: NQZ8-CME. ID: 3 | 2018-10-10 04:09:21
Intraday data recording state for symbol NQZ8-CME is set to download 'Pending'. | 2018-10-10 04:09:21
SC Data - All Services | Starting real-time market data updates for: YMZ8-CBOT. ID: 4 | 2018-10-10 04:09:21
SC Data - All Services | Subscribing to streaming market data in the service client is not supported. Symbol: YMZ8-CBOT | 2018-10-10 04:09:21
SC Data - All Services | Requesting security definition data for: YMZ8-CBOT. ID: 4 | 2018-10-10 04:09:21
Intraday data recording state for symbol YMZ8-CBOT is set to download 'Pending'. | 2018-10-10 04:09:21
HD Request # 2 | Downloading Intraday chart data for EMDZ8-CME to the file EMDZ8-CME.scid. Service: scdataallservices | 2018-10-10 04:09:26
HD Request # 2 | Download start date-time: 2018-04-07 04:09:26.000 | 2018-10-10 04:09:26
HD Request # 2 | Requesting historical Intraday Minute data for EMDZ8-CME starting at 2018-04-07 00:09:26 (Exchange time). | 2018-10-10 04:09:26
HTTPS historicaldata.sierrachart.com:443 (1) | Creating socket. Using TLS 1.2. | 2018-10-10 04:09:26
HTTPS historicaldata.sierrachart.com:443 (1) | Connecting to IP: 88.99.0.216. | 2018-10-10 04:09:26
HD Request # 2 | Error downloading historical Intraday data for EMDZ8-CME. Error executing query: Invalid symbol
| 2018-10-10 04:09:27
HD Request # 2 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for EMDZ8-CME | 2018-10-10 04:09:27
HD Request # 2 | Completion time: 0s | 2018-10-10 04:09:27
HD Request # 2 | Intraday data download complete for EMDZ8-CME. Unique request ID: 1 | 2018-10-10 04:09:27
Removed historical data download ID 1 | 2018-10-10 04:09:27
Real-time Intraday chart data file updates started for EMDZ8-CME | 2018-10-10 04:09:27
Opened cached Intraday file: C:\SierraChart\Data\EMDZ8-CME.scid | 2018-10-10 04:09:27
Intraday chart data file opened for EMDZ8-CME | 2018-10-10 04:09:27
HD Request # 3 | Downloading Intraday chart data for ESZ8-CME to the file ESZ8-CME.scid. Service: scdataallservices | 2018-10-10 04:09:27
HD Request # 3 | Download start date-time: 2018-04-07 04:09:27.000 | 2018-10-10 04:09:27
HD Request # 3 | Requesting historical Intraday Minute data for ESZ8-CME starting at 2018-04-07 00:09:27 (Exchange time). | 2018-10-10 04:09:27
HD Request # 3 | Error downloading historical Intraday data for ESZ8-CME. Error executing query: Invalid symbol
| 2018-10-10 04:09:28
HD Request # 3 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESZ8-CME | 2018-10-10 04:09:28
HD Request # 3 | Completion time: 1s | 2018-10-10 04:09:28
HD Request # 3 | Intraday data download complete for ESZ8-CME. Unique request ID: 2 | 2018-10-10 04:09:28
Removed historical data download ID 2 | 2018-10-10 04:09:28
Real-time Intraday chart data file updates started for ESZ8-CME | 2018-10-10 04:09:28
Opened cached Intraday file: C:\SierraChart\Data\ESZ8-CME.scid | 2018-10-10 04:09:28
Intraday chart data file opened for ESZ8-CME | 2018-10-10 04:09:28
HD Request # 4 | Downloading Intraday chart data for NQZ8-CME to the file NQZ8-CME.scid. Service: scdataallservices | 2018-10-10 04:09:28
HD Request # 4 | Download start date-time: 2018-04-07 04:09:28.000 | 2018-10-10 04:09:28
HD Request # 4 | Requesting historical Intraday Minute data for NQZ8-CME starting at 2018-04-07 00:09:28 (Exchange time). | 2018-10-10 04:09:28
HD Request # 4 | Error downloading historical Intraday data for NQZ8-CME. Error executing query: Invalid symbol
| 2018-10-10 04:09:29
HD Request # 4 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for NQZ8-CME | 2018-10-10 04:09:29
HD Request # 4 | Completion time: 1s | 2018-10-10 04:09:29
HD Request # 4 | Intraday data download complete for NQZ8-CME. Unique request ID: 3 | 2018-10-10 04:09:29
Removed historical data download ID 3 | 2018-10-10 04:09:29
Real-time Intraday chart data file updates started for NQZ8-CME | 2018-10-10 04:09:29
Opened cached Intraday file: C:\SierraChart\Data\NQZ8-CME.scid | 2018-10-10 04:09:29
Intraday chart data file opened for NQZ8-CME | 2018-10-10 04:09:29
HD Request # 5 | Downloading Intraday chart data for YMZ8-CBOT to the file YMZ8-CBOT.scid. Service: scdataallservices | 2018-10-10 04:09:29
HD Request # 5 | Download start date-time: 2018-04-07 04:09:29.000 | 2018-10-10 04:09:29
HD Request # 5 | Requesting historical Intraday Minute data for YMZ8-CBOT starting at 2018-04-07 00:09:29 (Exchange time). | 2018-10-10 04:09:29
HD Request # 5 | Error downloading historical Intraday data for YMZ8-CBOT. Error executing query: Invalid symbol
| 2018-10-10 04:09:30
HD Request # 5 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for YMZ8-CBOT | 2018-10-10 04:09:30
HD Request # 5 | Completion time: 1s | 2018-10-10 04:09:30
HD Request # 5 | Intraday data download complete for YMZ8-CBOT. Unique request ID: 4 | 2018-10-10 04:09:30
Removed historical data download ID 4 | 2018-10-10 04:09:30
Real-time Intraday chart data file updates started for YMZ8-CBOT | 2018-10-10 04:09:30
Opened cached Intraday file: C:\SierraChart\Data\YMZ8-CBOT.scid | 2018-10-10 04:09:30
Intraday chart data file opened for YMZ8-CBOT | 2018-10-10 04:09:30
[2018-10-10 04:41:45]
It looks like you want to use Rithmic based on the symbols. Follow the Setup Instructions on this page:
Rithmic Trading Platform Service
And it looks like you are missing a custom studies DLL file based on this error message:
You will need to contact the developer of that custom study about this.
Date Time Of Last Edit: 2018-10-10 04:43:05
