Date/Time: Wed, 22 Jan 2025 15:54:39 +0000
previous version
View Count: 963
[2018-10-09 23:13:03]
User398539 - Posts: 9
all my chart I have worked on for years are wrecked due to updating to the latest version ver: 1815 can i go back to A previous version, when my charts were perfect
i followed directions to do so! there are no other versions available? ugh
[2018-10-10 03:55:12]
In what way? This does not make sense why there would be a problem.
You can go back to a prior version. Refer to:
Software Download: Software Rollback Procedure
And if you need to access to a backup Chartbook, these are also available:
Chartbooks (Workspaces): Accessing a Backup Chartbook File
[2018-10-10 09:13:19]
Xfanman1 - Posts: 320
I hate to read things like this. Hopefully everything is intact in the automated backups that SC does for you. BUT, it is SO easy to make a backup copy of Sierra and store it on another drive or a flash drive because it’s ALL contained in one folder. Things go wrong, computers fail, hard drives fail, SSDs fail, power surges wipe out data. Don’t lose something you “Worked on for years” because you don’t have a backup.
If you get your charts back using SC’s suggestion, PLEASE make your own backup and keep it off that drive, just in case!
Scott
[2018-10-12 18:45:05]
Thank you ''I work on computers all day.. with that said i should have made a back up that that version... you would think reading the support board i could find pervious versions of sierra charts ..there are none !
so with a simple update
all my work is wrecked....... very upset
[2018-10-12 19:18:11]
We will call you and help with this. Set your current telephone number here and let us know when that is done:
https://www.sierrachart.com/UserControlPanel.php?page=ManageAccountInfo
