Date/Time: Wed, 22 Jan 2025 15:04:25 +0000
Service Activation Page: Missing $10/mo CTS Order Routing Connection Option
View Count: 637
[2018-10-09 21:34:30] |
tesseract353 - Posts: 66 |
http://www.sierrachart.com/index.php?page=doc/CTS_T4.php#LowCostConnectionModel_Requirements The link above states, "Activate the 10 USD per month CTS order routing connection. Can be activated on the Services Activation page." However, the Services Activation page found here: http://www.sierrachart.com/UserControlPanel.php?page=ServicesActivation is not giving me the option to activate the CTS order routing connection. |
[2018-10-09 22:02:19] |
We need to remove that. There is no longer any cost for this but you will need Service Package 5 to use that CTS connection.
