Date/Time: Sun, 24 Nov 2024 11:17:30 +0000
Most indicators in the same window.
View Count: 1300
[2013-10-28 19:03:00] |
bercor - Posts: 30 |
Could you kindly tell me how to put more indicators in the same window? example: I would like to put an RSI RSI 14 and 40. THE I program creates two windows. But I would like to have the two lines in the same window so 'gain space. you can put additional horizontal line? the RSi of deafault only has two, and I would like to add others. |
[2013-10-29 00:32:06] |
This is done through the Chart Region in the settings window for studies. Refer to the documentation here: http://www.sierrachart.com/index.php?l=doc/doc_ChartStudies.html#TechnicalStudySettingsWindow To add additional horizontal lines, refer to: http://www.sierrachart.com/index.php?l=doc/doc_ChartStudies.html#AddingHorizontalLine Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
