Date/Time: Wed, 22 Jan 2025 20:39:34 +0000
Numeric Table
View Count: 1187
[2018-10-09 19:07:52] |
User470516 - Posts: 78 |
Dear Sierra Chart Team, I have noticed that the source code for the study numbers bar calcultated value is not available. I am looking to draw a numeric table (cells or grid and labels on the left) like what is available in the above mentioned study or in a spreadsheet. Is there another study whose source code is available and that offers that kind of numeric table so that I avoid myself the development of that kind of table ? Thank you for your support. Regards, Laurent |
[2018-10-10 03:59:24] |
Yes. Look at scsf_NumericInformationGraphDrawTypeExample in /ACS_Source/Studies8.cpp
[2018-10-10 11:39:13] |
Thank you very much for this, it has helped me greatly already! I have some questions related to the s_NumericInformationGraphDrawTypeConfig structure. 1- Is there a documentation of that structure with all the associated members? 2- Is it possible to display objects instead of numbers in the cells (i.e. triangles up, arrows...)? 3- On the far right of the graph past the current bar, there is some additional space and the grid is still visible there. Is it possible to write into those very last cells at the far right end of the screen? Thank you again for your support. Regards, Laurent |
[2018-10-12 00:40:42] |
Give us some time to get back to you on this. We need to prepare some additional documentation and do some testing but item 2 is not supported.
[2018-10-24 08:06:14] |
1- Is there a documentation of that structure with all the associated members? This will be ready tomorrow.3- On the far right of the graph past the current bar, there is some additional space and the grid is still visible there. Is it possible to write into those very last cells at the far right end of the screen? Yes. You can place values into the chart column immediately after the last chart bar in the table. The documentation will explain this. It is accomplished by using s_NumericInformationGraphDrawTypeConfig::ShowPullback
[2018-10-24 20:42:05] |
John - SC Support - Posts: 37404 |
The documentation for the Numeric Information Table Graph Draw Type ACSIL features is now available. You will find it starting here: ACSIL Interface Members - sc.Subgraph Array: Numeric Information Table Graph Draw Type
