Date/Time: Wed, 22 Jan 2025 15:02:27 +0000
Bad trade signaling
View Count: 950
[2018-10-09 15:52:39]
User243224 - Posts: 2
I have a question
After entering the position in New Instance, the information line on entry and number of contracts is lost. after the end of the position is not the signalization of the trade. both triangles are on the same side. The store is not transferred to the Trade activity log in the New Instance. ... Signaling and writing works in the basic SC.
thank you for answer
Paya72, Prague Czech Republic
imageobchod_1__9_10_2018_2.JPG / V - Attached On 2018-10-09 15:51:23 UTC - Size: 440 KB - 323 views
imageobchod_1__9_10_2018_3.JPG / V - Attached On 2018-10-09 15:51:35 UTC - Size: 647.25 KB - 344 views
imageobchod_1__9_10_2018_4.JPG / V - Attached On 2018-10-09 15:51:44 UTC - Size: 177.42 KB - 332 views
[2018-10-09 19:23:56]
Update to version 1820 following these instructions:
And then refer to the information here:
Chart Trading and the Chart DOM: Accurate Entry/Exit State, Fill Matching and Position Quantities (Accurate Entry/Exit State, Fill Matching and Position Quantities)
From the sub instances clear the order fills for the Symbol and Trade Account following these instructions:
Trade Activity Log: Clearing Trade Activity Data
The above step is an important step to follow.
And then reconnect to the data feed:
Date Time Of Last Edit: 2018-10-10 04:07:56
