Date/Time: Wed, 22 Jan 2025 14:54:38 +0000
Adding Studies Together
View Count: 946
[2018-10-09 15:38:39] |
KXRCap - Posts: 64 |
SC - Is there a way to add 2 studies together and maybe take the average? Simple Example (RSI 14 + RSI 21)/2 ... I am interested in something a little more robust but that is the idea. Thanks. |
[2018-10-09 19:20:53] |
Refer to: Using the Basic Arithmetic Studies Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
