Date/Time: Sun, 24 Nov 2024 11:18:39 +0000
New Trade Activity Window look
View Count: 1657
[2013-10-28 18:15:26] |
Viacheslav Malafeev - Posts: 88 |
Dear SC, I appreciate all the changes you make to my favourite trading platform, but the new look of the Trade Statistics tab is definitely not one of them. Let me explain. 1. From usability point of view, only those lines in thise tab should be in bold that are crucial to reading the table. I mean the main parametres, the 1st paragraph (lines Total Profit/Loss... Profit Factor). All other lines needn't be in bold, because otherwise the table becomes unreadable, and it makes me want to downgrade to the previous version. I keep testing tens of Automated Trading systems during the day, and I can't properly use the Trade Statistics tab now. 2. The highlighted negative values should be IN RED. Please see this. http://screencast.com/t/FfRx6IlONb Thanks a lot! Date Time Of Last Edit: 2013-10-28 18:15:52
[2013-10-28 20:54:00] |
1. From what we can tell, one of the operating system fonts is being used. We are not specifying bold. Check the Windows Display settings in the Control Panel 2. We will see about this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-10-28 20:54:24
[2013-10-29 21:17:06] |
1. Sorry, but you are wrong. The Bold setting wasn't there before version 1039. I tested it on a different machine (which had version 1032), and it didn't have this bug, but as soon as I upgraded, the bold font appeared on that machine as well. Systems checked - windows 7 and windows 8.1. Please review this again. (The other issue with version 1039 is that my ACSIL system is making UNMATCHED FILLS only. The trades are open but never closed.) Date Time Of Last Edit: 2013-10-29 21:18:27
[2013-10-29 22:54:21] |
1. You misunderstood. The Trade Statistics tab has been completely redeveloped. So it is going to look different compared to a previous version. And we do not use a bold font . We do not know why it appears that way for you. Additionally we do not know why you had that very abnormal problem of it drawing very slowly. That must've been a system problem. In the next release, the font will be controllable through the Text Windows Font in Global Settings >> Graphics Settings. The appearance of a font, is not considered an "bug". This is an appearance issue. Why you see it the way you do, we do not know. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-10-29 22:54:44
[2013-10-30 08:35:53] |
OK, thanks for your assistance!
