Date/Time: Wed, 22 Jan 2025 14:46:20 +0000
Order Fill Lag
View Count: 1018
[2018-10-09 14:18:02] |
User104854 - Posts: 457 |
When I'm trading live the order fills on my chart show up a handful of bars back from where the actual entry and exit took place. It doesn't happen during replay. Could there be some sort of time setting I need to adjust? Please advise how to fix. Thanks.
[2018-10-09 16:23:45] |
This is explained here: Chart Trading and the Chart DOM: Misaligned Order Fill Markers on Charts Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
