Date/Time: Wed, 22 Jan 2025 15:01:17 +0000
[User Discussion] - Chart Scale Negative Values
View Count: 634
[2018-10-09 08:29:08]
Acro - Posts: 441
I have been trying to determine if there is any way to change the scale colors for negative values ?
Eg if one is using an indicator in region 2 and it can range between -2K and +2K is there an easy way to see that the scale values are negative rather than positive by way of a coloring ??
This becomes more important when you set the region scale to automatic scaling and at first glance you're not sure whether the value is say +500 or -500
