Date/Time: Fri, 31 Jan 2025 00:00:07 +0000
enable/disable study alert using ACSIL
View Count: 1266
[2018-10-09 06:47:06] |
aknsyu71@gmail - Posts: 54 |
Hi, Is there any way to enable and disable study alerts using ACSIL? (the same way that visibility can be controller via GetStudyVisibilityState) Also question two. In the Alert manager in a second instance of Sierra there are alerts from the main instance listed (Source: SC DTC Server). Is there any way to disable this and only have second instance alerts listed in the second instance Alert manager? Many Thanks for your help Andrej |
[2018-10-11 18:22:13] |
Is there any way to enable and disable study alerts using ACSIL? (the same way that visibility can be controller via GetStudyVisibilityState) Also question two. In the Alert manager in a second instance of Sierra there are alerts from the main instance listed (Source: SC DTC Server). Is there any way to disable this and only have second instance alerts listed in the second instance Alert manager? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-10-11 18:33:22] |
Thank you for the answer and for this fantastic software! May I suggest two more alert options. 1. option to not see "Web service response" messages in the alert log. it makes my alerts difficult to distinguish 2. option to have a persistent alert, ie keeps alerting until acknowledged by user Kind Regards |
[2018-10-11 19:26:48] |
2. The way to accomplish this is explained here: http://www.sierrachart.com/index.php?page=doc/GeneralSettings.html#PlayingAnAlertSoundRepeatedlyUntilManuallyStopped Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-04-02 19:31:56] |
Is it possible to enable/disable alerts of a study from another study using int AlertConditionEnabled? Could you post a short single line example please? Thank you |
