Date/Time: Wed, 22 Jan 2025 15:00:34 +0000
Cannot find: Global Settings >> Data/Trade Service Settings settings window
View Count: 557
[2018-10-08 20:56:58] |
User280700 - Posts: 1 |
Good day, I see following buttons on my screen: Main / Documentation /Getting Started/Account Management/ Support Under which button can I find "Global settings >>>Data/trade Service settings? I want to try out Bitmex trading Thanks for your support, Cheers, Lisette |
[2018-10-08 21:38:42] |
You need to install Sierra Chart on your computer system. Follow the instructions here: Software Download Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
