Date/Time: Wed, 22 Jan 2025 14:49:35 +0000
Alerts | Auto-Populating via a config file
View Count: 860
[2018-10-08 19:52:03]
TapeReader - Posts: 89
We use a bevy of audio alerts.
We would like to know if there is an easy way for us to populate our customer's instances of Sierra Chart with these so that their alert settings are automatically populated?
We would to mitigate issues that might arise from manually establishing all of these alert settings.
Screenshot explanation attached.
imageAlert Settings - Population.png / V - Attached On 2018-10-08 19:50:07 UTC - Size: 108.19 KB - 247 views
[2018-10-08 19:54:28]
Yes. This is in the main global configuration file that can be sent to a user. Refer to the instructions here:
File Sharing
But just make sure you are sending it from an instance of Sierra Chart that does not have any Global settings that you do not want to share.
[2018-10-08 19:54:30]
File Sharing
[2018-10-08 20:35:13]
If we use this approach, will we then overwrite any customizations that the recipient has made to Toolbars, Keyboard Shortcuts, etc?
Also, the approach recommended requires human intervention in terms of acquiring a Sierra Chart's Username/Account Name and also a manual generation for each user.
Is there a way that we could publish a config file on our download site, and/or, publish this file on the Sierra Chart file distribution system?
[2018-10-08 20:51:20]
Yes we can provide the global configuration file which you provide us, to your users Sierra Chart installations but it would only be used for a new installation of Sierra Chart.
Date Time Of Last Edit: 2018-10-08 20:51:59
[2018-10-08 21:23:55]
If we provide our .wav files to Sierra Chart, can these .wav files also be automatically installed into the C:\SierraChart\AlertSounds folder?
[2018-10-09 19:33:19]
Yes this is no problem. Provide us everything through an account support ticket here:
https://www.sierrachart.com/usercp.php?page=SupportTickets
