Date/Time: Wed, 22 Jan 2025 14:47:32 +0000
Stop settings when scaling in to position
View Count: 666
[2018-10-08 17:09:30] |
User993067 - Posts: 156 |
Is there a setting that will update my breakeven/trail settings after adding to initial position...so that they adjust based on average position instead of first position... While adding on to winners avg position increases and initial adjustments are not as desired. |
[2018-10-08 18:25:41] |
Yes this already happens. Make sure you are running the current version: Software Download: Fast Update You will also see an entry in the Trade Activity Log for the order indicating this is happening: Trade Activity Log: Viewing Historical Trade Activity Confirm you see that entry when scaling in. It will contain the text "Updating move to breakeven stop reference price". We plan to do some additional testing related to this but have not yet gotten to it. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-10-08 18:42:23] |
Thank you...I updated to latest version will look at stop settings.. However, Fonts on Volume by price study have increased by 50%...hard to read ...is there setting to change.... initially said downloaded with errors... |
[2018-10-08 19:22:48] |
In regards to font sizes, you need to adjust the Size of the Subgraph which is controlling the text size: Chart Studies: Subgraphs Tab >> Line Width Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-10-08 21:43:52] |
I have the settings VBP so that Bid - ASk Volume is displayed in the bars and color coded...the font has increased 50% upon upgrade to new version never has before...adjustments to subgraphs have no effect
Capture.PNG / V - Attached On 2018-10-08 21:32:53 UTC - Size: 51.93 KB - 241 views Attachment Deleted. |
[2018-10-08 22:54:14] |
And what particular Volume by Price study Subgraph >> Size setting did you adjust?
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-10-08 22:54:30
[2018-10-09 02:54:57] |
I did not adjust any settings... when I updated to newest version and opened my chartbook the text on the profiles had increased...a window opened after the install said the download occurred with errors. I reinstalled and same thing.. text on profiles is too large and distracting... Unsure where the adjustment to reduce font size...does not respond |
[2018-10-09 04:37:42] |
You need to adjust the Size for this particular Volume by Price Subgraph: Volume By Price Study: Volume Numbers Text Color and Size (SG7) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-10-09 04:37:53
