Date/Time: Wed, 22 Jan 2025 14:56:35 +0000
POC on TPO Profile Charts
View Count: 2030
[2018-10-08 16:28:32]
User536593 - Posts: 11
1)  POC MIGRATION: In the market profile, I would like to be able to highlight where the position of the POC was within each TPO column. Let me explain.
Look at the picture attached that shows the same MP both in its compact version, and “splitted”
If you look at the compact profile, some letters are in “yellow/gold” , these letters show the POC within the column of the TPO. In the example above I could see that POC migrates higher in the B,C,D and E period…. And then it stops migrating higher in IFG,H and J column¡ (actually only J is in gold, because of this platform setting)
imagePOC.png / V - Attached On 2018-10-08 16:25:56 UTC - Size: 233.52 KB - 511 views
[2018-10-08 19:52:13]
The only way to see the historical Point of Control values is to use the TPO Value Area Lines study:
It has an option to display the developing POC.
