Date/Time: Wed, 22 Jan 2025 14:59:05 +0000
trade management by study speed
View Count: 853
[2018-10-08 15:55:20]
Mauro - Posts: 45
Is it possible to have the adjustment frequency in the trade management by study shorter then one second?
Thank you
Mauro
[2018-10-08 18:28:09]
You just need to modify the study to meet your requirements. The source code for it is available in the /ACS_Source folder. Refer to:
How to Build an Advanced Custom Study from Source Code
Date Time Of Last Edit: 2018-10-08 18:28:30
[2018-10-09 18:41:25]
Mauro - Posts: 45
OK - I found the source code file. It is great that you provide that.
I will try to modify the study as you suggest.
Thank you
[2018-10-09 20:07:52]
Also know that the speed is going to be dependent on the Chart Update Interval as well:
Chart Settings: Chart Update Interval in Milliseconds (Chart >> Chart Settings >> Display >> Chart Update Interval menu)
