Date/Time: Tue, 22 Sep 2026 12:12:01 +0000
Text Color for Study Value
View Count: 2189
[2018-10-08 15:45:53]
nicktrader - Posts: 813
Is it possible to change the text color of the study values (similar to the price box).
As you can see from the attached pic the value for VAL is hardly visible.
imageText Color Study.png / V - Attached On 2018-10-08 15:41:54 UTC - Size: 57.02 KB - 570 views
[2018-10-08 19:00:39]
Yes this is possible to do and we are working on the documentation for this now.
[2018-10-08 20:38:56]
John - SC Support - Posts: 47955
You will find the documentation for this here: Chart Studies: Subgraphs Tab >> Label
[2018-10-10 08:34:40]
The "label option" is well known to me, but unfortunately not sufficient (from my point of view).
It would be really helpful if you could change the color of the font and the box (Reverse Color) separately.
As far as I can estimate, the color of the font is currently determined by the background.
imageStudy Labels.png / V - Attached On 2018-10-10 08:34:16 UTC - Size: 7.73 KB - 471 views
[2020-06-17 00:13:06]
j4ytr4der_ - Posts: 947
+1
I'm here almost 2 years later looking for the same thing, to be able to change strictly the color of the text and not the subgraph or the color of the box around the text (I use reversed colors). Would really like this flexibility.
