Date/Time: Wed, 22 Jan 2025 14:49:43 +0000
Fibonacci Time Tools (Configuration Settings)
View Count: 1295
[2018-10-07 15:22:49]
jomanos - Posts: 27
I am using the Fibonacci Price tools and Time tools, and saving multiple configuration settings for each tool.
With respect to the Price tools, the multiple configuration settings are saved and remembered by SC (saved as TC 1, TC 2, etc.).
With respect to the Time tools, the additional configuration settings, other than TC 1, are not saved or remembered by SC. I have to right-click on the drawing and select "Chart Drawing Properties" and re-save the configuration settings (for TC 2, TC 3, etc.) at the start of each session I use SC.
I think this is a bug, specifically for the Time tools (Time Expansion Tool, Time Projection Tool).
Let me know if you need me to post screenshots or a post a chart.
[2018-10-08 18:15:08]
We are not seeing this behavior and are unable to reproduce it.
Here is the documentation for configuring a drawing tool:
Chart Drawing Tools: Using Multiple Drawing Tool Configurations
[2018-10-08 22:23:56]
jomanos - Posts: 27
Ok. Thanks for looking into it.
There must be something I an doing wrong then. Will re-do the configurations from scratch.
Thanks again.
