Date/Time: Sun, 24 Nov 2024 11:31:45 +0000
Adjust Line color and thickness
View Count: 1303
[2013-10-28 15:39:53] |
User56044 - Posts: 62 |
In "Chart Settings" I have my bar period set on "Renko Bar", and the Graph Draw Type set on "Line on Close". My question is: How do I change the color of the "Line on Close" and its thickness?
[2013-10-28 17:31:00] |
This is done through Global Settings >> Graphics Settings.
