Date/Time: Wed, 22 Jan 2025 16:02:28 +0000
T A L Problems
View Count: 906
[2018-10-05 15:55:24]
SierraTraders - Posts: 69
My tal doesn't show 'fill to fill' or 'flat to flat' , 'drawdown or run up ' , ' running profit '
[2018-10-05 17:26:11]
Refer to this thread here:
Reimplementation of Trades and Trade Statistics and Period Trade Stats Tabs/Calculations
In regards to drawdown and run-up, those fields have been renamed to Flat to Flat Maximum Open Profit / Maximum Open Loss. And these are now properly calculated. We still need to document these fields. We will try to get to that today. And there still is a Running Profit/Loss. If there is anything you could see before which you cannot just let us know what it is and we will explain how you can see it or we can see how to add additional data to show you that information.
Make sure you are using pre-release 1816 to see these particular field names:
Date Time Of Last Edit: 2018-10-05 17:26:58
[2018-10-06 15:00:38]
User924791 - Posts: 12
V.1816 Using an all-in, scale-out strategy.
There seems to be a problem with the Running Profit/Loss (C) column calculation on the Trades tab. The Total Profit/Loss for Closed Trades value on the Trade Statistics tab is correct, but the Running PL is not.
Also, it would be helpful if the sort sequence on the Trades tab was Entry DateTime (asc) + Exit DateTime (asc). That way, the final trade (EP) would be at the bottom of the list of scale-out trades.
I can send a screenshot if necessary. Please advise.
[2018-10-06 22:40:35]
Yes provide a screenshot of this clearly showing the issue.
Since there is a first in first out fill matching method, the very final trade is at the end of the list of the series of trades which make up the flat to flat position Trade.
Also refer to the updated documentation here for the fields:
Trade Activity Log: Trades Fields Descriptions
Date Time Of Last Edit: 2018-10-06 22:51:14
[2018-10-07 04:10:16]
Both issues appear in the attached screenshot:
1. Discrepant Running PL
2. Exit DateTime in reverse sequence (the EP trade is not at the end of the list)
imageRunningPL discrepancy.png / V - Attached On 2018-10-07 04:06:58 UTC - Size: 121.78 KB - 255 views
[2018-10-07 04:44:21]
Okay we understand the issue. We are resolving this now.
[2018-10-07 06:19:48]
This is now resolved. We are going to be releasing version 1817 in about 20 minutes.
[2018-10-07 23:22:29]
One very minor issue with the Trade Statistics tab when either using File, Save Log As or Edit, Copy All is that there should be an additional tab before the First Fill column heading. Currently those column headings need to be moved one column right in Excel so that they correctly identify the data on the row below them.
Trade Statistics - Simulated  \tFirst Fill  Last Fill  Daily Date
Based on Fill To Fill  All Symbols (Non-Sim)  2018-10-04 05:34:56  2018-10-05 07:37:16  2018-10-05
Trivial, I know, but it'd save me a click'n'drag every time I paste into Excel. Obviously, this is so far from critical that it's barely visible. :-)
[2018-10-07 23:27:07]
Okay we will have a look at this.
[2018-10-08 00:43:26]
This is resolved in 1818.
[2018-10-12 22:46:06]
V.1821 using a scale-in, scale-out strategy.
The FlatToFlat Profit/Loss (C) column's values appear to be incorrect after awhile.
The trade sequence in the attached screenshot began with 1 contract long, added 1 more for 2, added another 1 for 3 total. Then it sold the 1st contract (total now 2) and soon bought 1 again (total back to 3). Proceeded to sell 1 (total = 2). Bought 1 again (total back to 3), sold 1 (total = 2). Finally, bought 1 (total back to 3), sold 1 (total = 2), and then flattened the remaining 2.
imageFlatToFlatPL discrepancy.png / V - Attached On 2018-10-12 22:43:45 UTC - Size: 53.63 KB - 260 views
[2018-10-12 22:49:25]
Provide us your TradeActivityLog.data file and we will look into the problem.
You can privately attach it here.
Date Time Of Last Edit: 2018-10-12 22:50:21
[2018-10-13 01:24:47]
No need to provide anything. We have it now corrected.
The problem was that particular field was not working as documented and instead was implemented in the same way as the the Flat to Flat Maximum Open Position Profit/Loss are implemented.
