Date/Time: Sun, 24 Nov 2024 01:13:30 +0000
Average Entry Price Line
View Count: 1385
[2018-10-05 14:58:54] |
User379884 - Posts: 45 |
Hi, When scaling in, is there any way to not have the average entry price of the multiple orders show, rather just keep each separate entry price showing on its own? Thanks. |
[2018-10-05 17:30:55] |
Not at this time but we will be looking at this perhaps sometime next year. One thing we will be adding though is different methods of calculation of the average price. You will be able to use first in first out or last in first out fill matching.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-10-05 17:31:33
[2021-12-03 17:20:48] |
Fabio - Posts: 115 |
Good morning. Are there any updates in regards to this topic? I saw it is quite old but I was trying to figure out if there's been some update to the platform recently that allows trades to show separately rather than averaging out the entry price. Thanks, Fabio |
[2021-12-03 18:08:00] |
There have not been updates to this. There is still just the one line.
[2022-01-19 19:03:22] |
User379468 - Posts: 508 |
Is this still planned?
[2024-06-20 00:08:29] |
User715603 - Posts: 2 |
Any updates on this being sorted?
[2024-07-09 00:41:06] |
Sierra_Chart Engineering - Posts: 17154 |
No, this is not going to change.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-07-09 00:41:13
