Date/Time: Wed, 22 Jan 2025 14:00:15 +0000
Long term on-demand tick data for futures
View Count: 699
[2018-10-05 13:48:49] |
pa_trader - Posts: 29 |
Does anyone know of a real-time datafeed for futures that has a few years of tick data history as well. I use IQ Feed but it only has 180 days of tick data history. Thanks ! |
[2018-10-05 17:42:36] |
You should use our Real-time datafeed, it has tick data history for at least five years and it is the best we have ever seen. We are tapping into the direct CME feed, decoding the data and sending it out using our own protocol, its a feed that has been developed that is custom for Sierra Chart: Sierra Chart Exchange Data Feed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-10-05 18:33:41] |
Yes, I just signed up for a trial. How do I a continuous adjusted price series for various symbols ? Thx |
[2018-10-05 20:58:32] |
Refer to this page: Continuous Futures Contract Charts Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
