Date/Time: Thu, 26 Sep 2024 23:31:20 +0000
Request- the ability to colour code the tabs
View Count: 597
[2018-10-05 13:39:40] |
Adam - Posts: 141 |
Would be nice to be able to colour code the tabs in the .CHT. Hopefully this request doesnt provoke the wrath of the support team... i will get back into my fox hole and await the shelling. |
2018-10-05_14h32_12.png / V - Attached On 2018-10-05 13:38:12 UTC - Size: 23.14 KB - 268 views |
[2018-10-05 13:40:32] |
User20450 - Posts: 330 |
+1
[2018-10-05 13:56:42] |
RIFT - Posts: 124 |
+1
[2018-10-05 17:39:28] |
We will take this under advisement. In the meantime, we just want to make sure that you are aware of the option to color the Active Tab separate from the inactive tabs. Refer to the following documentation and the items following it for doing this: Graphics Settings: Chart Selected Tab Color
