Date/Time: Wed, 22 Jan 2025 15:01:51 +0000
keyword/sierra condition for autotrading/alert
View Count: 606
[2018-10-05 12:08:17]
User525733 - Posts: 126
Is there a keyword/builtin SC function similar to "crossfrombelow" that checks whether two curves get close to each other without actually crossing and returns "true" ?
where can i find a list of all SC keywords similar to "crossfrombelow" ?
thanks
[2018-10-05 18:23:00]
In regards to the functions which can be used with Simple Alert formulas and Spreadsheets, refer to:
Spreadsheet Functions
[2018-10-08 23:24:13]
User748203 - Posts: 1
You can subtract the two and check to see if the absolute value of the difference is within your margin that defines "close to each other".
Suppose the two curves are ID1 and ID2, and you want to see if they are within 1.5 points of each other:
=if(abs(id1.sg1@3-id2.sg1@3)<1.5,1,0)
