Date/Time: Wed, 22 Jan 2025 13:46:26 +0000
NDX
View Count: 763
[2018-10-05 04:09:21] |
User28682 - Posts: 233 |
Does anyone know the symbol in SC for the equivalent to the NDX? NASDAQ 100 Index, cash. I tried searching in SC symbol lookup but couldn't find the pure NDX. Also, I set up an intraday chart for $SPX. It loads in previous data, but wont update in real time? All my other quotes seem fine. Thanks Date Time Of Last Edit: 2018-10-05 18:23:35
[2018-10-05 20:55:26] |
All of the NASDAQ symbols cash index symbols can be found here: https://www.sierrachart.com/index.php?page=doc/SierraChart_RealTime_And_Historical_Symbols.php&SymbolsPage=Indices#INDEX-NQ Also, I set up an intraday chart for $SPX. It loads in previous data, but wont update in real time? All my other quotes seem fine. For this you need to activate the S&P Indices exchange and instead use the symbol $INX. You can do that here: https://www.sierrachart.com/UserControlPanel.php?page=ExchangeDataFeedFeatures Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-10-05 20:57:41
