Date/Time: Wed, 22 Jan 2025 13:35:26 +0000
Barchart Data question
View Count: 1371
[2018-10-04 14:01:16] |
User350666 - Posts: 38 |
Dear Suppport, I am subscribed to SC realtime futures data of multiple exchanges. If I'm correct this data comes from Barchart. Can you please let me know if this data subscription also makes possible to access/use Barchart's data with other softwares? Can Barchart be contacted directly with this question? Thank you. |
[2018-10-05 19:17:12] |
To provision this data feed Sierra Chart is tapping into the direct CME feed, decoding the data and sending it out using our own protocol (it uses the DTC protocol), its a feed that has been developed that is custom for Sierra Chart. So with this implementation the answer is no but you could potentially access the data using the DTC server. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-10-06 08:00:12] |
Thank you this would be the best - usin DTC. I'm going to contact the other software developer if they are willing to add support for DTC, that would be great. |
