Date/Time: Wed, 22 Jan 2025 13:55:21 +0000
Volume profile question
View Count: 1317
[2018-10-04 09:49:58]
Ingmar Brouwer - Posts: 4
Hi there,
Does somebody knows if it is possible to have my profile on the far right and not under the price below a screenshot what i mean.
And if possible how to do this?
Thanks,
Kind regards
imagesierrachart question.PNG / V - Attached On 2018-10-04 09:48:58 UTC - Size: 130.78 KB - 677 views
[2018-10-04 10:18:44]
User907968 - Posts: 825
See image attached
1. Volume profile - align to far right - set to yes
2. Move price bars so that last bar is where you want on chart (ensure that 'Lock Fill Space is disabled first)
3. Enable 'Lock Fill Space' (see chart menu)
imagevp right align.png / V - Attached On 2018-10-04 10:18:28 UTC - Size: 164.9 KB - 402 views
[2018-10-04 15:11:04]
User750920 - Posts: 280
Thanks for this. When I set the Volume Profile to align far right it does not stay there if I use the scroll wheel.
[2018-10-04 15:19:33]
Ah yes, there is an option 'Always keep last profile within view', that should fix it for you I think.
[2018-10-04 16:00:33]
That was it thanks so much. There are so many inputs it is easy to overlook. By the way how did yo get the Chart studies window "and" the chart drop down menu in the same picture above. Whenever I have the studies inputs window open I cannot do anything else. Is there a setting allowing multiple widows to be opened - it would sure make it easier to review settings in one window against another.
[2018-10-04 16:10:49]
No problem.
Re the window & menu open at the same time, that was a cut & paste job in MS paint unfortunately.
[2018-10-04 18:13:55]
I am recent convert to Sierra. Came from another program that allowed any number of preference windows open at the same time. That was a nice feature, but I am enjoying the functionality of Sierra much more, so far glad I switched.
[2018-10-04 21:08:01]
thanks it worked..
[2018-10-05 19:47:40]
Here is the relevant documentation for the first question:
Volume By Price Study: Right Aligning Volume Profiles with Space on Right Side of Chart
Also when we redevelop the dialog windows in Sierra Chart, we will see if we can make them what is called "modeless". But at this point this it is just too soon to say.
