Date/Time: Wed, 22 Jan 2025 14:01:38 +0000
Price Display format and Tick Size
View Count: 1530
[2018-10-03 19:57:09]
User226793 - Posts: 173
Folks, can you please let me know how the price display format and tick size for NQ and ES on the numbers bar chart...For some reason it does not show me the right options to choose...
[2018-10-03 21:26:05]
First thing we want you to do is to update Sierra Chart to the current version:
After that follow the instructions here to apply the settings to the chart if the Tick Size is not correct:
Global Symbol Settings: Update/Apply Symbol Settings to Charts
[2018-10-04 17:27:21]
Thanks I followed the steps you asked me to do it did not fix the issue.. Please see attached screenshot... I just need the price to be displayed as per the index, could you please tell me what setting changes in need to make?
imageNQ.PNG / V - Attached On 2018-10-04 17:26:59 UTC - Size: 47.91 KB - 329 views
[2018-10-04 17:47:50]
We are going to give you a call and look at this issue remotely.
[2018-10-04 17:48:48]
Ok thank you... my number is 646 467 2630
[2018-10-04 17:55:28]
We are calling now.
