Date/Time: Wed, 22 Jan 2025 14:59:18 +0000
Using persistent data when a study is recalculated - erroneous code provided in the doc
View Count: 613
[2018-10-03 13:00:59]
User470516 - Posts: 78
Dear Sierra Chart Team,
I am trying to use persistent and, as stated in the documentation, I have noted that they increases when the study is being recalculated. I have therefore used the sc.IsFullRecalculation variable and the code suggested in the doc : https://www.sierrachart.com/index.php?page=doc/ACSIL_Members_Functions.html#scGetPersistentInt:
if (sc.IsFullRecalculation)//This indicates a study is being recalculated.
// When there is a full recalculation of the study,
// reset the persistent variables we are using
sc.GetPersistentInt(0) = 0;
sc.GetPersistentInt(1) = 0;
sc.GetPersistentInt(2) = 0;
sc.GetPersistentInt(3) = 0;
There is an error in the code as it resets the persistent variable at each iteration. it should incorporate something like :
if (sc.Index == 0)
Regards,
Laurent
[2018-10-03 18:23:45]
Yes this does make sense. But the documentation was probably written with manual looping in mind but we will update it anyway.
