Date/Time: Wed, 22 Jan 2025 15:02:08 +0000
Scroll bar and timescale not visible when chart attached to chartbook
View Count: 635
[2018-10-03 01:09:28] |
Basho - Posts: 2 |
When my primary chart is attached to chartbook, the time scale and scroll bar are not visible. If I detach the chart, they are visible. I have searched through documentation for solution, but cannot find one. Would appreciate your help.
[2018-10-03 01:45:49] |
Go to that chart and select Window >> Maximize to make sure it is properly maximized
