Date/Time: Wed, 22 Jan 2025 14:59:24 +0000
Q stick & Awesome occilator dot line style
View Count: 580
[2018-10-03 00:47:18] |
User845611 - Posts: 13 |
I just updated to latest version. Now settings>line style> dot is drawing in like a 'dash' setting. Is there a fix or do I need to go back to my previous version.
[2018-10-03 01:02:47] |
You will need to go back to a previous version. That style will remain.
