Date/Time: Sun, 24 Nov 2024 11:52:42 +0000
Cursor and changing colors on indicators
View Count: 1306
[2013-10-28 03:46:13] |
User123496 - Posts: 27 |
My cursor has a white box on the right chart edge for the number of the current level, but it's blank and unreadable. Also, when I create a horizontal or other line it will not change colors; like if I need to draw parallel lines. If I right click the chart and click colors to make them black there are two different blues, but no black available. Sorry, if this sounds trivial, but it's important to me.
[2013-10-28 04:05:09] |
You can change the color for the Chart Values tool through Global Settings >> Tool Settings >> Chart Values. You can change the color for any of the other tools through Global Settings >> Tool Configs. Here is the documentation for that: https://www.sierrachart.com/index.php?l=doc/doc_Tools.html#DrawingToolConfiguration Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
