Date/Time: Wed, 22 Jan 2025 14:49:58 +0000
Need Help Aligning the actual volume bars to the right of market profile
View Count: 627
[2018-10-02 22:24:30] |
NiceGuy23 - Posts: 2 |
Currently I have been having my volume bars run through my market profile to the left, is there a way that one can separate the two? I have the number of contracts traded at each level listed to the right, but would like to seperate my volume bars from going through profile. I basically have the opacity on the volume bars set to nothing. I'd like to be able to have market profile to the left and then the volume profile to the right, and would like for it be able display each day, not just todays profile. THanks
[2018-10-03 05:28:38] |
Provide an image of the chart or Trade DOM, by following these instructions: https://www.sierrachart.com/index.php?page=doc/PostingInformation.php#Image Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
