Date/Time: Wed, 22 Jan 2025 11:55:42 +0000
Prior OHLC variable period
View Count: 578
[2018-10-02 18:48:06] |
Chuck6475 - Posts: 24 |
I have two instances of Sierra Charts for ESZ8 (CB) daily. Both have the Prior OHLC study on them to signify the prior day's hi and lo. I have set the parameters for each study to be the same. The Chart Settings are the same, but something is wrong because I GET DIFFERENT RESULTS. The documentation is little help. What is different in the results. One gives the hi and low of yesterday the other gives the hi and low of who knows what. Instance A: results are hi 2942.00 and low 2922.50 (one set of lines) Instance B: results are hi 2912.00 and low 2889.75 (several sets of lines) settings for both are: time period: Days time period length: 1 Use current period: no Auto skip: yes Minimum: 5 Forward: Yes Number forward: 10 Number of days: 1 Display: no I'm assuming it has to do with Chart Settings but I can find any difference between the two of them. Ideas????? Version 1814 |
