Date/Time: Wed, 22 Jan 2025 11:48:52 +0000
Order Fills w/o text?
View Count: 594
[2018-10-02 17:33:28] |
jaxscott1 - Posts: 24 |
Is it possible to, when turning on Show Order Fills, to just see the enter/exit triangles with no accompanying text for price, profit/loss, etc.? Not seeing a setting if so.
[2018-10-02 18:09:39] |
Yes. Refer to the documentation here: http://www.sierrachart.com/index.php?page=doc/ChartTrading.html#DisplayingOrderFills Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
