Date/Time: Wed, 22 Jan 2025 11:36:33 +0000
Rithmic Singapore cannot connect
View Count: 669
[2018-10-02 16:11:55] |
Japhro - Posts: 120 |
I can connect and trade on Rithmic 01 US but cannot even connect to Rithmic Singapore to pull data. I use Rtrader also and given where I live, the Singapore server is more reliable for fills and speed/smoothness of quotes and updates. Is this disabled within SC or is it on my broker's end? I would really like to use Singapore for data and trading if possible
[2018-10-02 18:10:35] |
Update to the current version of Sierra Chart and see if that resolves the issue. Here are instructions: Software Download: Fast Update We cannot provide further help in this regard. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
