Date/Time: Wed, 22 Jan 2025 14:49:14 +0000
ask bid difference profile outline in number bars
View Count: 886
[2018-10-02 15:42:22] |
User99934 - Posts: 227 |
Line 53 does not seem to work when set to ask bid difference profile outline. Are there specific settings in other lines I should have to make it work?
[2018-10-02 18:48:47] |
Attach this chart following these instructions here: Support Board Posting Information: Providing Chartbook with Only a Single Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-10-02 18:48:53
[2018-10-02 19:22:04] |
File attached
Private File |
[2018-10-03 13:45:57] |
John - SC Support - Posts: 37369 |
We have been made aware of a problem with the Pullback column background and we are working on resolving it. Please give us a few days to get this resolved.
[2018-10-03 13:49:18] |
Thank you.
[2018-10-03 19:42:30] |
This will be resolved in the next release.
