Date/Time: Wed, 22 Jan 2025 11:39:37 +0000
1814 - TOOL CONFIG
View Count: 614
[2018-10-01 23:07:00]
Chuck6475 - Posts: 24
I downloaded version 1814 and have been building my setup. I use several variations of the Ext. Rectangle, more than 8.
In prior version when I was defining TC9 - TC24 there was a selection box below the "load" column. That option doesn't appear on version 1814.
I tried the drop box next to the Config Name box but if I update the settings it changes the setting on the "quick load" button which is selected and can't be unselected.
What do you suggest?
[2018-10-02 15:46:49]
John - SC Support - Posts: 37369
Sorry, we are a bit behind on the documentation for this. You need to select the configuration you want to modify in the dropdown box, as you have done, and then select the Load button. This then sets that as the active configuration you are working with. When you have finished making the appropriate changes, be sure to select the Save button to save that configuration.
